NI TestStand
Visual Basic 6.0 Locks Up w/Test Stand API 4.1 control
I have noticed that when I add the TestStand API 4.1 conotrol to a Visual Basic 6.0 (SP6) form, I am unable to close the the form.  Visual Basic locks-up and becomes unresponsive.  I have been able to reproduce this on different computers (same versions of software).  This also occurrs on blank forms and forms with other controls.  Just wondering if anyone else has run into this and if there is some type of work around or solution.
Thank you.
(3,222 Views)
Support for Visual Basic 6 was removed starting with TestStand 4.1. I have not tried this myself, but considering it is no longer supported, then it could be expected behavior.
You can find out more in the following KnowledgeBase article:
http://digital.ni.com/public.nsf/allkb/434A751B66D419F6862574500053BDBF?OpenDocument
Message Edited by CorbinH on 12-18-2009 08:28 AM
(3,199 Views)
