NI TestStand
To run the selected VI Step directly, double-click the selected VI step in teststand or click edit vi
Hello, everybody!
I want to be able to do the following in teststand,
When I insert a written vi step and set it in the VI execution property to run when open, when I open the VI with labview, it runs directly, but when I double-click the step in teststand, the VI is open in the edited way, not run directly,
Could you please tell me how to set it up or do it in teststand so that when I double click on it I can just run the selected step,
Thank you very much
(995 Views)
That's not intended behavior from TestStand. The double click, and the Edit VI button do the same thing of opening the VI for editing.
Your VI's will run as the sequence runs, manually opening the VI's so that they run should not be part of your process.
(982 Views)
What are you trying to achieve and why?
Santhosh
Soliton Technologies
(970 Views)
Have you tried right-click on the selected step and selecting Run Selected Steps?
(966 Views)
