To Tuxamation -
Nothing comes to mind as to why this would happen. VB 6 automation DLLs are used all the time for code modules.
Note that when MSVB debugs a DLL, it is actually running the DLL as an EXE server within the MSVB process and not in TestStand's process that is using it. I typically found that there is typically a subtle difference in behavior between running the server as an EXE or DLL server.
A simple way to determine if the TestStand call is reaching your DLL is to place a MsgBox function call in the DLL entry point and immediately return, ie. bybassing your existing code.
So, if the call is being made to your DLL, you could then enable the Visual Basic project option on the Compile tab, "Create Symbol Debug Info" and recreate your VB DLL.
You can then attach Microsoft Visual Studio (C++ debugger) to the TestStand process, open the file that contains the entry point in to DLL that TestStand calls, set a breakpoint, and see if the breakpoint is reached.
Scott Richardson
Scott Richardson
https://testeract.com
