10-20-2009 12:23 PM
HI,
I have a chip handler program w/ui in CVI that I have running TestStand sequences through ActiveX. I pass pointers into TestStand for the data returned by the tests. The TestStand sequences call functions in a DLL created through CVI. How can I debug in both CVI and TestStand. I am trying to verify the complex data structures. I would like to see the actual variables in both programs to verify that everything is mapped properly. I know I could use print statements in TestStand but it would be messy.
Mike
10-20-2009 03:27 PM
Hopefully the following link will help
http://forums.ni.com/ni/board/message?board.id=330&message.id=6467&query.id=1242867#M6467
regards
Ray Farmer
10-22-2009 09:27 AM
I read that thread before I posted mine. Unfortunately it doesn't really apply. I am running an exe created in LabWindows which use ActiveX to run test sequences. The test sequences run functions from a DLL. I have no problem debugging the DLL and exe, I don't know how to link in to debug TestStand. I can debug just the sequences and DLL using TestStand, but the situation I have is more complex in that the data comes from an EXE which then calls the sequences. I need to start in CVI and then have the TestStand debugger start. If not, is there a way to link an exe to TestStand. I hope this make sense.
Mike
