Two responses in Message pop up step
Hi all...
Can we configure the message pop up step to get two response strings seperately...
Can this be done in the existing step or should we create a custom step type to do this...
(3,865 Views)
hi,
you will have to create a custom step based on the existing Message Step to do this.
regards
ray farmer
Regards
Ray Farmer
(3,860 Views)
Is it possible to change the existing post step of the message pop up step to show two responses. In the existing message pop up step there is one post sub step that uses dll tto show the pop up... i do not know how to edit the C code to modify it a required. Is it possible to change the arguments of the dll to show two responses...?
(3,858 Views)
It might be easier for you to just create a module in LV, C or whatever you program in, that looks like the message popup but has two string controls that get returned.
jigg
CTA, CLA
testeract.com
(3,836 Views)
Can you use the single entry but seperate the two inputs, then parse the values from the Response string.
eg "1#5.0;2#4.5" If you identify which entry value is then it doesn't matter in what order of if one entry is missing.
Regards
Ray Farmer
Regards
Ray Farmer
(3,822 Views)
You must have some awesome operators Ray!
jigg
CTA, CLA
testeract.com
(3,805 Views)
No just a big stickSmiley Very Happy
I surpose if its in the operator's instructions, then they should just follow those instructions or how they were trained.   Not Idea but it might be an easier route.
Regards
Ray
Regards
Ray Farmer
(3,799 Views)
