NI TestStand
UI Message Help - Send Array to the UI via ActiveX
I have asked a similar questoin before but now I'm having issues trying to get a array to the UI via UI messaging. I'm my TestStand code I have an expression to send a array that is located as a FileGlobal array container to the UI as such:
RunState.Thread.PostUIMessageEx(UIMsg_UserMessageBase + 2,0, "", FileGlobals.DataRead, False)
and in the UImessage callback I have what I thought I should do to send the data to a text table on the UI. This is not working.
Can someone tell me what I'm doing incorrectly?
Attached is the UIcallback, Control and a picture of the table on my UI
Bill Lewis
Message 1 of 14
(9,537 Views)
You can't directly pass the data in a UIMessage.  You can, however, pass a reference to ThisContext.  Then, you can modify your UI Message Handler to query for that value, directly using TestStand - Get Property Value.
Message 2 of 14
(9,507 Views)
Like this?
Bill Lewis
Message 3 of 14
(9,503 Views)
Yes, but you can use the TestStand - Get Property Value.vi directly with the TS.SequenceContext reference and avoid casting variants into other things.
Message 4 of 14
(9,496 Views)
Thanks for the help JGruenberg.
I have tried and it seems that the TS.SequecneContext is not correct or I'm not doing something correct. Attached is what i changed. Any other suggestions?
Bill Lewis
Message 5 of 14
(9,478 Views)
What exactly is happening? Is that callback executing? Is there an error?
Message 6 of 14
(9,470 Views)
Here is the error the callback is giving during the UI 10001 message
Bill Lewis
Message 7 of 14
(9,465 Views)
Your SequenceContext control is not connected to anything, so its not going to have a real value.  You need to get your sequence context from the UIMessage object's ActiveX member.  This is how you'd do that:
Message 8 of 14
(9,458 Views)
I'm close! Smiley Very Happy
I get a LabView error stating that a null value or deleted value was passed to the UImessage so I'm assuming this is because of my UI message format. Do i need to put the runstate.thiscontext? there or is this correct?
UI Message code to 10001 and 10002:
RunState.Thread.PostUIMessageEx(UIMsg_UserMessageBase + 1,0, "", Nothing, False),
RunState.Thread.PostUIMessageEx(UIMsg_UserMessageBase + 2,0, "", Nothing, False)
the step before the UI message is a multinumeric test and in the post expression I'm writing the data to the fileglobals with
FileGlobals.DataRead == Step.NumericArray
Bill Lewis
Message 9 of 14
(9,448 Views)
"Nothing" in there should be replaced with ThisContext.  You might want to change it to be synchroneous (changing the last parameter to True).
Message 10 of 14
(9,445 Views)
