UIMSG_Trace
Accepted by VipinrajKK
Hi Norbert,
You are right!
Its generating error when the reference is invalid and no error popup.
It will give the result of sequence call in the main sequence.
Thanks for the Support. Have a great day!
Message 11 of 13
(1,334 Views)
I want to add a recommendation, a rule of thumb:
Close all references you created/obtained programmatically (e.g. PreviousStep) and leave the references you get as parameter untouched.
Two remarks:
- Close them in any case. Don't wire it in the No Error case!
- Close them in opposite order or "inside-out"
Norbert
Expert: Geometry
Message 12 of 13
(1,325 Views)
Noted.
I will update the code based on your suggestions.
-Thank you
VipinrajKK
Certified LabVIEW Architect
Message 13 of 13
(1,322 Views)
