UUT Numbering (indexing from 1 instead of 0)
I would like the test sockets in batch mode to be indexed starting with 1 instead of 0 so that UUTs show up as UUT1, UUT2, UUT3, etc. in the report. Is this possible in TS4.0? I saw the posting at http://forums.ni.com/ni/board/message?board.id=330&message.id=10193&query.id=75159#M10193 but we are using LabView, not CVI.
Many thanks,
Chris
(4,168 Views)
Accepted by Tomahawk1277
Modifying the report is simply a matter of changing the 'Add Test Socket Index' step in the AddReportHeader sequence of the appropriate reprotgen_???.seq and assuming you are not using the DLL report gen option. If you want to change the display of the opertor interface, then I think the only way is to use CVI or rewrite the interface with LabVIEW.
(4,164 Views)
Thank you, Dennis. Works perfectly.
For any others trying to do the same thing, I also had to modify the AddBatchUUTItem callback within reportgen_xxx.seq so that the indexing was correct in the batch report header.
(4,141 Views)
When using TestStand 4.2.1, in "AddReportHeader" temporarily increment TestSocket Index right before the "Get XML for UUT" step.
(3,634 Views)
