UUT serial numbero to VI labview
Hello guys,
Please, I'm trying (without sucess) to use the serial number from UUT field in test stand to VI labiew. I need to use the serial number into string field (extreme simple). But I don't know how to do this...Please I need help.
(4,313 Views)
Accepted by topic author vpinho13
Try something like this:
You'll need to pass ThisContext into the VI when you call it from TestStand.
Hope this helps,
Trent
(4,300 Views)
Nice!!
Works... please one more question. I'm using action in step types. Whats is the best to check this?
 When I use action every time to fail I need to check error out. Its possible to use another steps types?
Thanks again
(4,291 Views)
I'm not sure that I understand the question.
You can use the Pass/Fail Test Step and return a boolean pass/fail value from your VI. Or you could use the String Value Test Step to pass or fail based off an expected string.
Hope this helps,
Trent
(4,248 Views)
