Unable to create variables under Paramter.Model Plugin.AdditionalOption
Hello Everyone,
I m unable to create a variable under model plugin Parameters.ModelPlugin.AdditionalOptions . The insert field option is disabled here.
Can you help me to enable this option.
or
is there a way to create the variable under AdditionalOptions?
-Vipin
(1,104 Views)
Accepted by Vipin@AMP
AdditionalOptions seems to be a custom data type. You should check the definition
(1,081 Views)
Right click "AMP_ExcelResultProce..", and select View/Type Definition. That will take you to the definition. Add your variable there, it will automatically update on your sequence.
Sergio Velderrain
LabVIEW Open-Source Program Manager
CLA I CTA I LabVIEW Champion Emeritus
"Linkedin profile"
(1,044 Views)
Thanks for the support.
Now I'm able to add the variables.
(1,013 Views)
