NI TestStand
Unable to find the Teststand Model Path File
I am unable to find the Teststand Model Path as specified in the NI Website, which says it should be Here:
"The default process model sequence file is TestStand\Components\NI\Models\TestStandModel\SequentialModel.seq"
This Path seems to be leaving out preceeding Path Location?  Like C:\ or C:\Program Files\...  etc., ...
If partial paths of this in the Program Files sub-directory and in the C:\user\public\... sub directories, but never able to find the full path as specified by NI's WEB site.
(3,107 Views)
The sequential model by default is included in the installation directory for TestStand. The default is listed in this help documentation based on your installation and product settings. For example, the preceding <TestStand> listed in the help for TestStand 2017 64-bit would be C:\Program Files\National Instruments\TestStand 2017.
Hope this helps!
Roxy
(3,102 Views)
Hope this helps!
Roxy
That path ends at c:\Program Files (x86)\National Instruments\Teststand 2017\Components
the next Sub-Directory path in this path should be "NI\", but NI does not exist...  there are still a few more sub-directories beyond this...  Such as:  Models\TestStandModel\SequentialModel.seq
(3,089 Views)
Accepted by topic author Edmund.M.Williams
Hey Edmund,
It's unclear to me where you're getting that information. In the first help I linked, the subdirectories you list are shown in the path for the sequential model.
(3,085 Views)
@RoxtheFox wrote:
Hey Edmund,
Thanks for your help, you were right, it was in a different place, than the NI online documentation said it was.  A path that did not include the directory "\NI"...
(3,077 Views)
