NI TestStand
Update / Saving StationInfo file
I am: Reading a boolean from  the StationInfo.txt as..
e.g.:   RunState.InitialSelection.SelectedFile.Data.Seq["MainSequence"].Locals.StationInfo.MyBool.
I am calling a sequence from the tools menu section which then calls a Labview Vi.
I can read / update the value. Is there a Teststand command to save the value directy back to the StationInfo.txt file?
If this is the wrong approach to uodate the StationInfo.txt file, is there a better way? Via a tools menu selection.
Message Edited by Ted 724 on 11-12-2007 07:18 AM
(3,197 Views)
StationInfo.txt is not a default TestStand file- it is likely something that your company created as a customization.  The TestStand Engine does not know anything about this file.
Allen P.
NI
(3,188 Views)
If StationInfo is just a Container in your Locals. You could try using the PropertyLoader. Your can also use the Export/Import Tool from the Tools menu.
Regards
Ray Farmer
Regards
Ray Farmer
(3,183 Views)
