Use API set defaultt Font Size for Report View
Dear
As the subject, how to Use API set defaultt Font Size for Report View.
I want set "Small" as default, Thanks!
Message 1 of 9
(3,812 Views)
Are you doing this in a custom UI or in the Sequence Editor?
jigg
CTA, CLA
testeract.com
Message 2 of 9
(3,770 Views)
Yes, I build my own Custom UI by TS, can you help me?
Message 3 of 9
(3,755 Views)
What language are you using.  Here is a picture on how to do it in LabVIEW:
jigg
CTA, CLA
testeract.com
Message 4 of 9
(3,736 Views)
Hi jiggawax
I am using C#, but "axReportView1.TextReportFont.Size" is read only, I can't set it, what should i do? thanks!
BR
Tab
Message 5 of 9
(3,731 Views)
That seems odd because in LabVIEW I can write to it.
jigg
CTA, CLA
testeract.com
Message 6 of 9
(3,728 Views)
Also, check out this from the TestStand Help.  It talks about how to use it in C#.
http://zone.ni.com/reference/en-XX/help/370052R-01/tsuiref/infotopics/font_objects/
Cheers,
jigg
CTA, CLA
testeract.com
Message 7 of 9
(3,726 Views)
Accepted by TabZhang
Based on the Help I'd say you need to create the Font object and set the properties and then assign the ReportView.TextReportFont to the newly created object.
Hope this helps,
jigg
CTA, CLA
testeract.com
Message 8 of 9
(3,724 Views)
Hi Jigg
Ok, Thanks for your help.
BR
Tab
Message 9 of 9
(3,717 Views)
