NI TestStand
Use Post Expression to convert 1.000 to 99999
I have a program that reports a 1.000 if the value returned is 1.#INF, by using the Val() function.
Can I use Post Expression to check to see if Step.Result.Numeric == 1.000 and if it is then convert it to 99999?
Currently I have Val( Step.Result.Numeric ) in the post expression box.  My version of TestStand is too old to use an If statement.  In most cases the value returned will not be 1.#INF so I want to make sure I don't convert every result to 99999.
Thanks in advance.
(3,096 Views)
Try
(Step.Result.Numeric == 1.000) ? (Step.Result.Numeric = 99999) : 0
Regards
Ray
Regards
Ray Farmer
(3,080 Views)
