NI TestStand
Use the data typ "array of container" in teststand
Accepted by Cabio
I think there are misunderstandings on both sides.
First off: An array is defined for one datatype. So the array element have to share the same type, in your case "container".
So, your array is already "Container"!
A container in TestStand is a datatype which enables you to add "fields". Container1, your local variable, defines several fields for a single container.
The Array_of_Container1 is an array with elements of type container, but it is not necessary that each container shares the same fields!
So what you essentially have to do in order to get an array containing lots of "container1"-container: copy your prototype into the array as many times as required. This will create new containers in the array sharing the same fieldnames and -types for each individual element. Then you can populate data for each field in each element individually.
hope this helps to clear things up,
Norbert
Norbert
Expert: Geometry
Message 11 of 12
(2,064 Views)
Thanks a lot Norbert_B and hsm78,
I think, I have got the point.
my fault:
variable                           type
array_of_container         array of container
container1                      container1
the solution could be:
variable                           type
Regards
Cabio
Message 12 of 12
(2,054 Views)
