NI TestStand
User manager file does not work for teststand deployment
I have checked User manager file (Station Options -> User Manager -> Configure) to be located on specific location.
Deployable computer has the authorities to open this file. However, When I build deployment with my development computer and install it on deployable computer, user manager file does not work.
I use "Simple user interface" to open sequence, so I cannot change stations options on my deployable computer.
How can I solve this?
(2,623 Views)
Accepted by AndrazS
What version of TestStand are you using?  That setting is stored in StartupCfg.ini in TS 2017.  So if you want the deployment machine to look at the new location for the Users.ini file you need to deploy that file as well.  Here is more on the different cfg files: https://zone.ni.com/reference/en-XX/help/370052W-01/tsdeploysystem/infotopics/configurationfiles/
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,595 Views)
