ā03-20-2006 11:50 AM
str(Parameters.StartDate.Text,"mm-dd-yy")
ā03-20-2006 05:59 PM - edited ā03-20-2006 05:59 PM
Sumit,
The second parameter of the Str() function is an optional string that specifies a C(printf) format string to control the conversion.
In the example you provide the second parameter is not a valid C format string.
That is why your expression does not evaluate.
I am not sure what you are trying to accomplish.
Could you attach a single example?
Where did you read that that could be done?
Best Regards.
Antonio Lie.
Message Edited by Antonio Lie (NI) on 03-20-2006 06:00 PM
ā03-20-2006 06:05 PM
Locals.Header +="Test Start Time"
+","+ (Locals.StartDate.Month <10 ? str(Locals.StartDate.Month,"0"šstr(Locals.StartDate.Month)) +"-"+(Locals.StartDate.MonthDay <10 ?str(Locals.StartDate.MonthDay,"0"šstr(Locals.StartDate.MonthDay))+"-"+ Mid(str(Locals.StartDate.Year),2,4)+" "+(Locals.StartTime.Hours <10 ?str(Locals.StartTime.Hours,"0"šstr(Locals.StartTime.Hours))+"-"+(Locals.StartTime.Minutes <10?str(Locals.StartTime.Minutes,"0"šstr(Locals.StartTime.Minutes))+ "\n"ā03-21-2006 12:21 PM - edited ā03-21-2006 12:21 PM
Sumit,
The format strings help document is not related to the Str() function.
I can see why you got confused though.
The Format Strings listed in that document are used in your system regional and languages options.
Start->Control Panel->Regional and Language Options ->Customize.
If you change those settings, it will affect the way your entire system displays date and time.
That also will affect the way TestStand displays the standard date and time.
Going back to the string formatting issue:
The correct way to format your string will be the following:
Locals.Header = "Test Start Time: " + Str(Locals.StartDate.Month,"%02u") + "-" + Str(Locals.StartDate.MonthDay,"%02u") + "-" + Right(Str(Locals.StartDate.Year,"%u"),2) + " " + Str(Locals.StartTime.Hour,"%02u") + ":" + Str(Locals.StartTime.Minutes,"%02u") + ":" + Str(Locals.StartTime.Seconds,"%02u") +"\n"
Notice that the format string is "%02u". It indicates that the width should be always 2 and if it is less than 2 it should prefix 0's.
Check the "printf" documentation for more information: http://msdn.microsoft.com/library/default.asp?url=/library/en-us/vclib/html/_crt_printf.2c_.wprintf....
Notice that I used the "Right()" function instead of the "Mid()" function.
I am also attaching a TestStand 3.0 sequence file that uses the "Time()" and "Date()" functions to obtain the current time.
I save them under local container variables similar to yours and finally format them using the previous expression.
Hope it helps.
If you have any question let me know.
Antonio Lie.
Message Edited by Antonio Lie (NI) on 03-21-2006 12:24 PM
ā03-21-2006 12:26 PM
