NI TestStand
Using GetFormattedValue with Boolean Array to create ReportText
What is the C (printf) style format for outputting a Boolean array?
I currently use to get
Step.Result.ReportText = Locals.Outlets.GetFormattedValue("",0,"",False,"\n")
Outlet State
Status: Done
Module Time: 1.6116278
False
True
False
False
False
False
False
False
I would like to format the output to show:
Outlet State
Status: Done
OFF
ON
OFF
OFF
OFF
OFF
OFF
OFF
(4,941 Views)
Hi Phillip,
interresting question, because the c-style doesnt know a datatype "boolean".
So i am quite sure there is no support.
You can do a simple workaround by using twice SearchAndReplace to rename True and False
in the same expression
Hope that helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,913 Views)
