09-04-2014 08:55 AM
We have migrated our application from Teststand3.5/CVI8.0 to Teststand2014/CVI2013.
It operates on development machine (with associated licenses).
I'm preparing setup on execution machine but can't reach a result.
I've on the execution machine the following applications
* NI Labview Run-Time Engine 2013 (64 bits)
* NI Labview Turn-Time Engine 2013 SP1 f2
* NI Labvwindows/CVI Shared Run-Time Engine 2013 SP2
* NI Labvwindows/CVI Side-by-Side Run-Time Engine 2013 SP2
* NI Measurement Studio Common .Net Assemblies for .NET 4.0 and VS2010
* NI teststand Runtime 2014 (32 bit)
* NI teststand Runtime 2014 (64 bit)
* NI Update Service 2014
The Processor is 64-bit, one DLL of application is 32-bit only, so I assume I need 32 bit runtime but not sure of which one I've to launch.
I start sequence with TestExec and get an error message:
Error in call LoadPanelEx
Parent Pannel Handle : 0
UIR File Name: TestExec.uir
Panel Ressource ID: 4
hInstance: 0x00400000, D:\Workspaces\W43_1540\TestExec.exe
Error code -145
ActiveX control not registred on this computer.
It seems to be related to a missing or not valid runtime but they are freshly installed.
Where should I look for?
PS: this morning, I've been able to reach TestExec but with an error message "sequence edited with a newer version, can't use it", so I've reinstalled the Teststand 2014 version without more success
09-05-2014 03:59 AM
To go on the issue, I've tried the Deployment Utility.
I discover that Deployment function is not included with Development licences? Is it true? If so, why can I open the menu and start the tool without warning?
It looks like my sequence is very huge and its analysis, including sub directories is very very long (more than 6h...)
