Deployment on Teststand2014, without Deployment tool
We have migrated our application from Teststand3.5/CVI8.0 to Teststand2014/CVI2013.
It operates on development machine (with associated licenses).
I'm preparing setup on execution machine but can't reach a result.
I've on the execution machine the following applications
* NI Labview Run-Time Engine 2013 (64 bits)
* NI Labview Turn-Time Engine 2013 SP1 f2
* NI Labvwindows/CVI Shared Run-Time Engine 2013 SP2
* NI Labvwindows/CVI Side-by-Side Run-Time Engine 2013 SP2
* NI Measurement Studio Common .Net Assemblies for .NET 4.0 and VS2010
* NI teststand Runtime 2014 (32 bit)
* NI teststand Runtime 2014 (64 bit)
* NI Update Service 2014
The Processor is 64-bit, one DLL of application is 32-bit  only, so I assume I need 32 bit runtime but not sure of which one I've to launch.
I start sequence with TestExec and get an error message:
Error in call LoadPanelEx
Parent Pannel Handle : 0
UIR File Name: TestExec.uir
Panel Ressource ID: 4
hInstance: 0x00400000, D:\Workspaces\W43_1540\TestExec.exe
Error code -145
ActiveX control not registred on this computer.
It seems to be related to a missing or not valid runtime but they are freshly installed.
Where should I look for?
PS: this morning, I've been able to reach TestExec but with an error message "sequence edited with a newer version, can't use it", so I've reinstalled the Teststand 2014 version without more success
(4,568 Views)
To go on the issue, I've tried the Deployment Utility.
I discover that Deployment function is not included with Development licences? Is it true? If so, why can I open the menu and start the tool without warning?
It looks like my sequence is very huge and its analysis, including sub directories is very very long (more than 6h...)
(4,544 Views)
