Using IVI driver for reading delay in MSO6104A
I have the NI IVI driver for the MSO6104A scope. The driver is functional and I manage to use it.
My scope has a function of measuring delay between two different channels. But, how can I read the Delay measurement using IVI scope step?
Is there any other way of reading this measurement?
Thanking in advance
(3,366 Views)
Accepted by Berezka
As far as I know, interchannel delay is not a supported IVI measurement function. So, you can complain to ivifoundation.org first of all. Or, in a code module, you can use the instrument specific driver to get the measurement. This would make the application 'non-IVI' so most of the reasons for using IVI in the first place are gone. Or, retrieve the waveforms from each channel and calculate the delay in a code module.
(3,354 Views)
Thanks, Dennis!
(3,325 Views)
