NI TestStand
Using Teststand with handler for pcb panels
Hi Guys
I'm new in this forum and hope you can help me.
I have a robotic handler which contacts one PCB in a panel of 8 PCBs. There are 4 PCB-panels (so totally 32 DUTs).
What is the propper way to handle DUTs in PCB-Panels (one per time, not parallel).
I read something about the Batch mode, but I think this is only for parallel testing.... right?
I'm still learning TestStand and there are so many possibilities to solve this, but I think there are aleady built-in functions in TestStand.
1. How to loop through the single DUTs? (Do I have to set up a loop in MainSequence or are there already pre-defined functions/callbacks?)
2. Where should I put the VIs for moving the handler to the next DUT?
3. How to handle the report?
Thank you so much
kind regards
micromanu
Message 1 of 1
(919 Views)
