NI TestStand
Using customized sequential model together with Simple OI
Hi
I'm using NI's Simple OI to run my sequence. If the sequence is using the default sequential model, everything works fine. If I change the model to my customized copy of sequential model, the following happens:
  • From sequence editor, everything works as expected
  • When I open the sequence in Simple OI, it looks like the sequence does not have its model at all. There is no execution entry point. All the icons of callback sequences are colored as if they were ordinary sequences.
...and the same thing happens with full-featured UI. What am I doing wrong?
Vladimir
Message Edited by Vladimir Drzik on 04-14-2008 05:06 PM
View my profile on LinkedIn
(3,253 Views)
Accepted by Vladimir_Drzik
Ooops, sorry for bothering, I've just solved it. I was using relative paths and didn't set up the search directories.
Vladimir
(3,248 Views)
Hi Vladimir,
No problem, thanks for posting your solution!!
Jervin Justin
NI TestStand Product Manager
(3,219 Views)
