‎11-08-2005 06:25 AM
‎11-08-2005 03:02 PM
Hi Murali,
There are many synchronization examples here:
<TestStand>\Examples\Synchronization\
For example, one is called QueueDemo.
As for your question about Thread Priorities- you should use the thread priority set to 15 to indicate a time critical application. I'm not really sure what your use case is. If you simply want to run two sequences in parallel, you can call them using the Sequence Call Step Type, and choosing to run them in a new thread.
Allen P.
NI
‎11-09-2005 07:10 AM
‎11-09-2005 01:23 PM
