NI TestStand
VI runs one more time after "exit" instead of returning to TestStand
Ive got an event structure inside of a while loop.  On the "exit" event, ive got a "true" wired to to while loop "stop if true" icon.  When running the VI by itself, the exit button works just fine.  But, when called from TestStand, im required to press the exit button twice to exit the VI and return to TestStand and continue with the TS sequence.
Any ideas as to why that is?
thanks
(2,944 Views)
What version of labview and TestStand are you using and can you post a small example showing your problem.
Regards
Ray Farmer
Regards
Ray Farmer
(2,929 Views)
