NI TestStand
Teststand IVI Steptypes
hello,
i have a problem with the teststand ivi teststeps
when i try to use the dmm step i get the following errormessage: Session Manager: niDMM_InitWithOptions returned an error: -1074118656. Unknown status code (-31619).
perhaps everyone knows the error.
i have configured the dmm in max for use with ivi drivers
k.-h.
(3,264 Views)
Hi Fischer,
The most common cause of this error is having an incorrect Instrument Descriptor. Is your DMM locally or on a remote PXI system? Please check the following:
http://digital.ni.com/public.nsf/websearch/22CF7E6B27B6995B86256DDB0058F39B?OpenDocument
Is it possible to use the DMM from LabVIEW, CVI or any other development envirnoment?
Let me know if you have success with that.
regards,
Nikolai
(3,241 Views)
hi nikolai,
i used the DAQmx instrument descriptor in the hardware asset, and now it works.
thank you
k.-h.
(3,219 Views)
