Vector CANoe compatiblity using NI TestStand
Hello All Big Guns,
Vector OpenTest, tests are modeled in a graphic notation based on UML. Test-specific elements are added to the options in the UML state diagrams.  This gives test designers a form of modeling that is adapted to the domains of ECU testing.
This OpenTest supports the test automation systems, CANoe from Vector and TestStand from National Instruments.
Do the National Instruments is having something which supports NI TestStand and CANoe from Vector?
My customer requirement is to create sequences using TestStand which can peform the same task in vector CANoe too....
Your comments will be imortant for us....
Regards-
Vaibhav
Regards:
Vaibhav Kanchan
Sr. Engineer
NI Certified LabVIEW Developer(CLD)
NI Certified TestStand Developer(CTD}
(4,860 Views)
Well Vector do a LabVIEW CAN driver, therefore you could write TestStand sequences which use these LabVIEW dirver VI (or probably code modules which call these CAN driver VIs).
[This OpenTest supports the test automation systems, CANoe from Vector and TestStand from National Instruments]
Not sure what this statement implies (I read this from there e-catalogue) maybe you should ask Vector.
Regards
Ray Farmer
(4,854 Views)
Looking at the Vector OpenTest information, it suggest there is a generator built-in which will generate NI TestStand sequence/SequenceFile.
Regards
Ray Farmer
(4,851 Views)
I am using CANoe in TestStand. But i never used OpenTest.
Maybe i do not understand the question about the requeriements.
Do you like to transform your openTest code to NI-TestStand
or  should TestStand Sequences just control and manage CANoe from scratch?
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,842 Views)
