NI TestStand
Wait for step execution to complete
I'm using COM adapter to call the TestComplete application.  There are several steps in the sequence file, one of which is to run a particular script in TestComplete.  However TestStand doen't wait for the TestComplete to finish executing the script, beforeproceeds to the next step.  I tried inserting a Wait step but couldn't get it to work correctly( e.g. wait till testcomplete send a return value back).
Thanks!
(3,370 Views)
Accepted by ph2
TestStand will wait until the function it calls completes.  It sounds like the TestComplete API returns before it's execution finishes.  I would look into that API to see if TestComplete actually supports this use case.
(3,362 Views)
