NI TestStand
Wait for step execution to complete
I'm using COM adapter to call the TestComplete application.  There are several steps in the sequence file, one of which is to run a particular script in TestComplete.  However TestStand doen't wait for the TestComplete to finish executing the script, beforeproceeds to the next step.  I tried inserting a Wait step but couldn't get it to work correctly( e.g. wait till testcomplete send a return value back).
Thanks!
(3,368 Views)
Accepted by topic author ph2
TestStand will wait until the function it calls completes.  It sounds like the TestComplete API returns before it's execution finishes.  I would look into that API to see if TestComplete actually supports this use case.
(3,360 Views)
