NI TestStand
Warning message using teststand 3.5 deployment tool
When I try to use the deployment tool i get the following warning :- Warning, a property(s) is being loaded using the property loader step which uses an expression to identify the file. then a list of occurences. Is there a way to get rid of this warning please? Many thanks
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(3,190 Views)
The only way to remove the warning is to not use an expression for the file in the Property Loader.  This warning can be ignored as long as you know the expression will evaluate to a valid file.
Allen P.
NI
(3,180 Views)
It does execute on its own so should be ok Many thanks
(3,176 Views)
