NI TestStand
Execution View panels updates
In the png attached, I show the out-of-the-box ExecutionView  of TestStand 4.0 with an example sequence file loaded.  I would like to customize our OI slightly in this area to move the Break/Terminate buttons to the right of the Threads box  I'll have those two buttons and a third (custom status indicator) in this new box.  I see that I'll have to update the file Full UI - Update Drage Bar Between Execution Variables CallStack and Threads.vi.  What I'm wondering, is how to get those buttons into a nice box (like Thread and CallStack are in) such that the border seamlessly blends in with Thread.
(3,016 Views)
Hello mrbean,
There are a number of decoration controls in LabVIEW that can be used to customize the appearance of a VI.  I believe it is one of the lowered or recessed boxes that are used to hold the front panel components you are referring to.  You should be able to find the decorations palette under the All Controls palette or Modern palette depending on what version of LabVIEW you are using.  I hope that helps.
Marty H.
(2,972 Views)
