NI TestStand
Web based APIs developed in C
We are planning to develop a web based application in C and create dll for the library and wrapper layer. Can we add this dll in the test sequence and call the APIs provided by the dlls in Test Stand? Specifically is there any limitation from Test stand to call a web based API developed in C or .net?
Priya Kuriakose
(3,195 Views)
What exactly would you be doing in these dlls? Most likely there is no difference in calling them from teststand versus calling them from any where else.
-Doug
(3,190 Views)
The dll will probably use some api or socket to send a http request similar to how the browser will create and send http request. Is there any limitation on TestStand for this?
Priya
(3,175 Views)
Ideally, there should not be any limitations. If you are facing any specific issues, please revert with details of the problem.
Chinmay
Chinmay Anand Misra
CLD
Technical Marketing Engineer
NI IndRA
(3,166 Views)
