NI TestStand
test step status information
I wonder where I can find the information for the test step status?  ie. for example, when it will return Pass/Fail, when it will display Done, True, Skipped, and if there is any other status?
Thanks.
Peggy
(3,101 Views)
Accepted by topic author PeggyC
Look in the TestStand Reference Manual in Chapter 3.  There is a table which shows exactly what happens when a step executes.  It's table 3-3.
Also, look in the TestStand help.  In the Index tab type ResultStatus and you should see all the ResultStatus constants.
http://zone.ni.com/reference/en-XX/help/370052H-01/tsapiref/reftopics/stepproperties
  • ResultStatus_Done–(Value: "Done")
  • ResultStatus_Error–(Value: "Error")
  • ResultStatus_Failed–(Value: "Failed")
  • ResultStatus_Looping–(Value: "Looping")
  • ResultStatus_NoStatus–(Value: "")
  • ResultStatus_Passed–(Value: "Passed")
  • ResultStatus_Running–(Value: "Running")
  • ResultStatus_Skipped–(Value: "Skipped")
  • ResultStatus_Terminated–(Value: "Terminated")
  • ResultStatus_Waiting–(Value: "Waiting")
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,094 Views)
Also table 3-4 in the TestStand Reference Manual is a good one to look at as well.
jigg
CTA, CLA
testeract.com
(3,092 Views)
jigg, Thank you!
(3,085 Views)
