What is the NI Switch Executive Advantage? Any Downside to Use this Product?
Can you please explain a little more about: Do the routing kind of manual (??)and not with the nice schematic drawing approach that you get if you buy NI cards...
Al
Message 11 of 13
(2,985 Views)
Accepted by LvCoder123
The NI cards are integrated into switch executive such that you can easily set up your routes through pictures of the switches.  I'm guessing, I haven't used them, that the Pickering ones are more manually entering in the routes without the pictures.  Basically you have to know the route names and such.
I think if you just get the eval and play around with it you can see how easy/hard it will be for you.  It is trivial from TestStand once you have it set up in Switch Executive.
Hope this helps,
jigg
CTA, CLA
testeract.com
Message 12 of 13
(2,979 Views)
Hi Jigg,
Al
Message 13 of 13
(2,954 Views)
