NI TestStand
What is the difference between Deploy TestStand system(3.1) and Run Engine Installation wizard(1.0) in Tools menu
   In TestStand 1.0 we can
(3,395 Views)
Hi ,
 Sorry in my pervious queries i hit the enter keys  without knowing myself.
In Teststand1.0 we can create "SetupTSEngine.exe" and "TSEngine.cab" files by executing "Run Engine Installtion Wizard" in Tools Menu.
The same files i need to create in TestStand 3.1.Whether "Deploy Teststand System" in Tools menu do this? or Is there any other option?
Thanks in advance,
Sivanath.
(3,393 Views)
Deploy TestStand System will allow you to create an installer in which you can include the TestStand Engine.
Allen P.
NI
(3,380 Views)
Hi Allen,
 Can i use the same "TSEngine.cab" file which was created by executing "Tools Menu - Run Engine Installtion Wizard" in TestStand1.0
Sivanath
(3,366 Views)
HI Sivanath,
You will want to include the engine by specifying it in the deployment utility.  For more information about deployment you can take a look at Chapter 14 in the TestStand Reference Manual.  If you look in this chapter you will also see a whole section on Common Deployment Scenarios.  The first one in this section discusses including the TestStand engine.
Caroline Tipton
Data Management Product Manager
(3,351 Views)
