NI TestStand
uppercase conversion
Is there a way in TestStand to convert operator input to upper case?
(4,290 Views)
You can use the expression function ToUpper().
eg Step.Result.Response = ToUpper(Step.Result.Response)
this would ensure the response from a MessagePopUp would be in upper case.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(4,283 Views)
You can force any string to upper or lower case with the ToUpper and ToLower expression functons.  I'm not sure what version these functions first appeared in, but they are in 3.1.
(4,281 Views)
Version 3.0.
Ray.
Regards
Ray Farmer
(4,277 Views)
