Whats the meaning of this Error
Hi All, Can any one explain me this error? When I am converting response i got from message popup to float64 I am getting this error It will cause run time error, if i give continue I am getting proper output. Best Regards Manasa M
(5,396 Views)
And what exactly is "this error".  What is the response you get?  How are you doing the conversion?
(5,389 Views)
Sorry for the improper communication .. image was not attached.
please check this image:
(5,371 Views)
The Result.Response variable is a string, that's why you get this error. The Float64() function expects a number.
(5,358 Views)
Accepted by ManasaM
If you want to get the entered "number of iterations" from the Message Popup step, better use the Val() function:
Locals.numberOfIterations = Val(RunState.Sequence.Main["Select number of iterations"].Result.Response)
(5,355 Views)
Actually i found this function (float64()) in TestStand for loop example.
Where do i get the list of functions available in TestStand?
Best Regards
Manasa M
(5,353 Views)
You find all available functions in TestStand help.
if you create an expression, click on this symbol f.PNGfor expression browser.
You will see all the functions in a structured way for numeric, string etc. with their help:
(5,345 Views)
