NI TestStand
Whats wrong with my expession?
whats wrong with this expression?
(( Locals.ChannelA.Info.Input.ID.Name != "" ) && ( Locals.ChannelA.Info.Output.ID.Name != "" )) ? ( Locals.ChannelA.Limits = Locals.Limits.LimitsList[ Val( Locals.Test.Current.ChannelA.LimitName ) ] )
The error messages says Unexpected token: "?". Basically I'd just like to implement an IF structure. The expression is in expression tab of a statement type step.
Must be something mega obvious...
(3,110 Views)
Accepted by 1984
ANSI C defines a boolean if clause as <Boolean Criteria>?<TRUE>:<FALSE>.
Looking at your expression, there is the complete <FALSE> branch missing.
EDIT: I stated the part with ANSI C because TS is implementing the same syntax
Norbert
Expert: Geometry
(3,105 Views)
I see... is there a "do nothing" command in TestStand? Or should I just put simply a False constant to the false branch?
(3,101 Views)
False should work fine, but my favorite is to use the keyword Nothing
(3,079 Views)
Thanks! All clear now.
(3,074 Views)
