NI TestStand
Where are Report Options settings stored locally?
Where (folder/file) are the settings stored on computer for things like Report Options, etc.?  Is it a .INI file we can view?
(2,770 Views)
Most of those settings are stored in the "TSAppData\Cfg" folder, which is located in a directory similar to C:\ProgramData\National Instruments\TestStand 2019 (32-bit)\Cfg.  Most specifically on the report options, dive deeper into the ModelPlugins folder to find ResultProcessing.cfg.  This is actually an XML file.
(2,760 Views)
(2,755 Views)
Accepted by testergi
By Report Options UI, you are referring to when you go to Configure -> Result Processing? I'm also assuming you are using a default Process Model, because the behavior can change if you are using a custom one.
But by default, all that information is saved to "C:\ProgramData\National Instruments\TestStand ###\Cfg\ModelPlugins\ResultProcessing.cfg"
It updates when you close out of that Result Processing window. And the timestamp will change if you made changes.
If that is not doing it, I would check your Environment. Configure -> Environment. If it's not set to the Global environment, or if you have enabled custom directories, it will save to a different place.
(2,702 Views)
@ShockHouse  Thanks for the help.  That was what I noticed where I pointed my config directory to another location under Configure > Station Options... > Preferences > Configuration Directory.
(2,661 Views)
