NI TestStand
Where do I find the sequence file name inside the Expression Browser?
HI,
I would like post the user with a simple question of whether this is the sequence file he meant to load. I want to use an expression rather then typing the question. The problem is that I don't seem to find the proper expression for that. I looked inside "RunState.SequenceFile" and I find everything related to my sequence file except to its name.
Can you help me?
Rafi
(3,272 Views)
Something is wrong with my TestStand installation so I can't test this. I think you could use the NameOf function, like NameOf(RunState.SequenceFile).
- tbob
Inventor of the WORM Global
(3,267 Views)
Hi Rafi2003,
The SequenceFile doesn't have a Name property. It has a Path property instead.
Regards
Ray Farmer
Regards
Ray Farmer
(3,257 Views)
