NI TestStand
how can I find the object reference : ApplicationMgr
I use TS 3.0 and Visual C++.
I would like to use the User Interface API : ApplicationMgr.ReloadModifiedFilesInterval, in an activeX step or in my code under Visual C++.
I success to declare it: TSUI::IApplicationMgrPtr ptrApplicationMgr;
but how can I find the object reference : ApplicationMgr.
In fact, I don't know how use ApplicationMgr?
(3,092 Views)
The TestStand UI Application Manager is an ActiveX control. In order to use it, you just have to place an instance of the ActiveX control on your interface. Then you will be able to access the methods and properties of the instance of the object. You don't have to create a pointer to an ApplicationMgr.
(3,057 Views)
