NI TestStand
Where is my report
The temp report file is created but does not appear in the report directory. This was working and then for some unknown reason quit. Any ideas?
(2,953 Views)
Swed,
Did you change the report options configuration?
I assume you are using the 'Use Temporary File' option.
Remember that the report generator deletes the temporary file when you close the execution window.
Hope this helps.
Antonio Lie.
(2,940 Views)
