NI TestStand
how get windows installation path
Hello, Is there a simple way to get the windows installation path inside TestStand?
thanks,
Mauro Magni
(3,567 Views)
If you mean the path to where TestStand is installed, it is Engine.TestStandDirectory.
(3,554 Views)
No, I meant the path where operating system is installed (generally c:\windows or c:\winnt)
I found a way to get it (calling a batch file which reads the variable %WINDIR% and pass the result to TestStand as a return code) but I'd like a better way...May be a TestStand store that path somewhere?
(3,543 Views)
Have you tried the GetEnvironmentVariable function in the Win32 API?  This function is documented on MSDN  I've attached a sequence file that retrieves the value of WINDIR.
I am the founder of CnCSoftwareSolutions. When not cleaning up baby drool, I write about test data or work on Vision, a tool for understanding your test data. Visit me at www.cncsoftwaresolutions.com
(3,531 Views)
