NI TestStand
Where is the Report dll code?
The Report options Dialog box includes an option to build the report from a DLL. The help section reads:
If you select the DLL option to generate your report, the TestReport Callback calls a function in a DLL to build the report body. The DLL report generator is a single call into a C-language DLL that processes the entire result list for the execution before returning. You can access the project and source code for the LabWindows/CVI-built DLL. If you select DLL, TestStand generates reports faster but does not call ModifyReportEntry callbacks.
Where is the project for this DLL and what is it called?
(3,011 Views)
Hi
The Report dll code is found in Modelsupport2.dll
The source of this dll can be found under \Components\NI\Models\TestStandModels.
The project name is "modelsupport2.prj"
I hope this helps
Regards
Anand Jain
National Instruments.
(3,004 Views)
