NI TestStand
Where to check UUT_RESULT.UUT_STATUS?
best place to do this would be PostUUT callback as this currently displays your PASSED/FAILED banner (in the default PostUUT).
Regards
Ray Farmer
Message 11 of 14
(1,092 Views)
Hm
PostUUT callback !
seems i was on the wrong garden path.
This happens if you hijack a thead Smiley Tongue
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 12 of 14
(1,087 Views)
Guys, can u explain how to make this callback sequence? And how to access the right property from PostUUT?
Message 13 of 14
(1,082 Views)
Check out Chapter 6: Overriding a Process Model Callback in the Using TestStand Manual (not the Reference Manual), it will take you through the steps.
Basically you need Edit»Sequence File Callbacks then select the required sequence callback
Regards
Ray Farmer
Message 14 of 14
(1,080 Views)
