NI TestStand
Which is the best way to Log result in Database?
Vidula S. wrote:
[...]With On the fly report writing enabled - Is there a way I can stop each and every step report writing, but club the report writing part for say 10 steps. (to reduce the File I/O processing)?[...]
No, that is not possible. OTFR writes to disk in more or less constant timeframes (if there has been results to be put into the report during this time of course). Maybe you should take a look into this documentation. It explains the standard generation of the report and does not go into detail for OTFR. Nevertheless, i hope that you will understand the way TestStand is collecting data for the report after this.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 11 of 12
(987 Views)
I think I have collected all the required information.
Thank you all for your suggestions/responses.
-Vidula
Message 12 of 12
(970 Views)
