NI TestStand
Which updates are free for TS4.0?
i have a licenced 4.0-teststan-version.
Which updates/patches can now be installed for free?
I saw a lot of downloadable zip-file but i am not sure which of them i can use?
TestStand4.0.1f1Patch236977
TestStand4.1Patch231477
TestStand4.1.1Patch231478
TestStand4.1.1Patch236979
4.2
4.2.2
and more
Thanks for help
(2,987 Views)
I am NI Application engineer. If you want to know which products you can access I must have a look at your Serialcode. Its no problem if you install patches that are not included in your licence. They will just not work.
If you wanna know exactly I advice you to start a service request via ni.com
If you don't have a Service license you can also sent me the number via personal message in this forum. (That's on your own risk)
In conclusion you can either just install everything without knowing exactly or sent me your code
Kind Regards
Chresten von der Heide
Applications Engineering
(2,966 Views)
You could also go to http://www.ni.com/activate and try your serial number against the different versions of TestStand.  Then you know which ones it will work for if it gives you a code.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,962 Views)
