NI TestStand
browse button kills TS
I have a dll, which has a browse button on its front panel. I call this dll from TS, use the browse button to select a file, then end the dll. This works only if I right click on the step and "Run selected steps". If I run the complete sequence with the RUN button, the front panel of the dll appears, but by clicking on the browse button, TS and the dll hangs, and I see "(Not responding)" on the window title of the dll.
The dll is compiled with LV2010 SP1, and I call it from TS 2010 (eingine and editor version 4.5.0.310)
any help is appreciated!
(3,001 Views)
I understand that you are using the NI Sequence Editor as interface for TestStand.
Do you use a standard NI process model?
If not, does your model already use this DLL?
Is there a certain reason for the VIs to be compiled into a DLL before included in a TestStand Sequence? You know, using the VIs directly is probably the better way....
Norbert
Norbert
Expert: Geometry
(2,988 Views)
we have to use the dll, because this dll is used woldwide on our testsystems, and our software concept doen't allow to use VIs - only frozen software modules.
I don't use any model, and I call this dll once in the entire sequence. On other test systems there is no such a problem, thos systems have the same versions of all NI products and windows.
(2,986 Views)
Can you reproduce the issue with a single step calling the DLL?
If so, can you post the sequence file and the DLL?
Norbert
Norbert
Expert: Geometry
(2,983 Views)
