NI TestStand
While running a Teststand sequence using command line arguement,report is not generated.
I am trying to run a sequence file in command line by double clicking a .bat file containing the command:
"C:\Program Files (x86)\National Instruments\TestStand 2014\Bin\SeqEdit.exe" /run MainSequence "<Sequence_Path>/Test_Sequence.seq" /quit
1.Teststand environment opens
2.Executes the sequence
3.Teststand closes
4.Report path doesen't have any report of this run.
Note: All steps were Result recording enabled.
(555 Views)
Accepted by ராஜ்(Raj)
Reports are generated by the ProcessModel.
You need to specify an Entry-point from the Model to run your sequence with
(523 Views)
Hi Oli_Wachno,
Tested using the entrypoint and now the report generation happens.
Thank you.
(497 Views)
