NI TestStand
Who do I contact to demo a system for measuring (in realtime) actual torque with digital readout?
It's not clear from your question if you have a system you want to demonstrate, or if you want someone else to demonstrate their system. If it is the latter, then I suggest you contact one of NI's alliance members (www.ni.com/alliance).
Mark
(3,567 Views)
Mark,
Point well taken! My company has a system for measuring driveline torque. It is called MONITORQ. Who would I contact in Austin for aproduct demo: about a 10 minute event. It could be described as a low level sensor gathering input for a plc etc
(3,567 Views)
You should get in touch with your local Field Sales Engineer. Go to ni.com/niglobal for a listing of worldwide local NI contacts. The Field Sales Engineer can either demo the system for you or put you in touch with the right person in your area.
(3,567 Views)
